I need 2 voltages for my project: 5v for an Arduino Nano, and 34v to power a MingHe B3603 that will be used as a current limiter, feeding 30v 20mA (to an ionic silver generator).
I've never stepped up voltage before, so forgive my ignorance.
The Arduino needs 5v at the Vin pin, and will be using less than 100mA. I'm not exactly sure how much current the B3603 draws when outputting 30v limited at 20mA, but I'm guessing it's not a large load.
Could I use a 5v wall wart, use that for the Arduino's Vin pin, and also use that for stepping up to 34v to feed the B3603? I've made a project like this before by combining 2 wall warts and then stepping them down for the Arduino, but I'm trying to avoid the mess of having 2 wall warts.
Thanks!
