Author Topic: LM294012CT linear LDO regulator.  (Read 877 times)
Offline sureshotTopic starter
« on: August 14, 2018, 11:33:43 am »
Just a quick question on the LM294012CT. I've used this regulaor with a rewound transformer of 14.70 Volts AC it worked out ok after filtering. But i was wandering if its viable for use with a 12 Volt transformer, after filtering it would be about 16.92 Volts DC. It would probably be a bit higher than that, as the transformers put out 13 Volts some even close to 14 Volts. I know I've got 1.4 Volts drop across the bridge rectifier. And would be using a series pass transistor,  so probably another 0.7 volts drop. The regulator has a 0.5 drop out voltage. So do you think a 12 Volt transformer would be viable ?
Thanks for reading, any help appreciated.
Offline CJay
Re: LM294012CT linear LDO regulator.
« Reply #1 on: August 14, 2018, 12:06:56 pm »
Your transformer is rated to provide 12VAC at it's rated load, measuring it off load is likely to give  a higher voltage which will drop when it's loaded.
I'd answer no, it's probably not going to be good enough.
The following users thanked this post: sureshot
« Reply #2 on: August 14, 2018, 12:23:23 pm »
Thank you for your reply, i did think it might be border line area . But wasn't 100% sure. Thanks again.
Offline CJay
« Reply #3 on: August 14, 2018, 12:40:09 pm »
Check your PMs
Offline Zero999
  • 0999
« Reply #4 on: August 14, 2018, 01:06:03 pm »
It might work, if Schottky diodes were used for the bridge rectifier and a massive filter capacitor.
« Reply #5 on: August 14, 2018, 06:31:10 pm »
Yes I did think it might be possible with those diodes for a bridge, and a high capacitance, capacitors with a high ripple voltage rating. I think it's really all on the transformer, if it's got more than 12 Volts, and can hold an AC load.
