I have a broken PWM control board for inductive loads, 24A, input 10-40V DC (not stabilized)
There is a LM317 to supply DC to IC (IC markings are erased but I suspect SG2524) about which I have a question.
I dont understand LM317 configuration here, if someone please explain that to me.
How does the feedback voltage from OUT gets to REF pin of the LM317, there is a resistor divider, OK I follow that, but then there is C2 cap that follows, separating the resistor divider from the rest of the cirucit, Can feedback loop work correctly with C2 placed there ? There is no current flowing from OUT throu resistor deviders, only during charge/discharge. Assuming C2 is charged to some V, can LM317 operate correctly and stabilize the V to the board ?
From what I manged to probe, the bottom connector of C2 goes to 12-13 pin of the IC (right row, two middle pins), the SG2524 has collector of two output transistors there.
cheers
