#tautech Yeah i almost ordered 10 of all three but my misses fussed a bit..... She says i'm just like a kid!LOL
Like a kid in a lolly shop.
Do you think the LM350T's will work ok? I was also thinken I could just move the larger 12v bundle (5 leads combined) and the matching ground bundle to my temporary input terminal to cover the added current draw while I'm testing things.
Adjustable regs are just so easy to use, who cares if they warm the room a little, they're not on ALL the time.
They're quite heavy those leads, I'd have no concerns putting 10 Amps through each conductor.
Now have a good think about how you might use this PSU and voltages required.
+ & - 15 for opamps etc won't happen with linear regs but 12 + & - is near enough.
12 + and 12-
+5 and +3.3.
Those should be your SET voltages, with outputs for each.
Then, as you have plenty of 12V current available, why not 2 identical adjustable supplies from 12V?
TBH I mostly use voltages in the lower ranges, although my home buit PSU is capable of 30V & 5A.
I used LM338 and LARGE heatsink, but a dual LM350 PSU @10.8V & 3A plus fixed outputs sounds good to me.
As you have a few
check out this datsheet with adjustable current using an additional LM350:
http://www.onsemi.com/pub_link/Collateral/LM350-D.PDFEverybody has to build a PSU......it's a right of passage.
EDIT
Haha, ditto datasheet.
