FCB, I thought of using FM as well but I am a newbie and I though that I would learn much more,
if I try to find the cause of the problem. If I fail, I will try FM. (and mess up even more
Hideki, very good explanation! Thank you. When I was trying to figure out why they were using
the capacitor/resistor to ground, I couldn't find any info. Then, one website was supposedly
explaining the reason.
http://www.learningaboutelectronics.com/Articles/How-to-connect-a-LM386-audio-amplifier-chipIt turns out that not only the explanation was wrong but the LM386 wiring was totally wrong as well...
w2aew, yes the problem is definitely in the S2L part, because when I used the 555 to test the
frequency response, the result was much better. (but still there). I need to make a LED pulser
that will have the same amount of light intensity up to 100Khz and then look at the L2S circuit
for similar problems.
Thank you very much for your help!
