Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
LM723 Power Supply Problems
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: LM723 Power Supply Problems (Read 3570 times)
potatogun96
Contributor
on:
July 02, 2014, 06:43:47 pm »
I built a power supply based off of this design:
http://www.eleccircuit.com/regulator-0-30v-5a-by-ic-723-2n3055-2part/
After building the circuit and checking all my connections, I tested the circuit. The output remains constant, slightly over 30 volts. The LM723 started to heat up, and R4 also started to burn, so I replaced it with a 1k ohm resistor. The output is still constant, but the resistor is not burning like before.
Are there any modifications I should make before replacing the chip with the extra LM723 that I have? I do not want to damage the remaining chip.
Logged
SeanB
Super Contributor
Country:
Re: LM723 Power Supply Problems
Reply #1 on:
July 02, 2014, 07:09:03 pm »
Remove Q1 and Q2, and short between pin 11 and the bases of the 2 power transistors. R5 can be 1k.
You also have your pinouts wrong. Refer to the data sheet.
http://www.ti.com/lit/ds/symlink/lm723.pdf
Save the remaining 723, they are very nice chips.
Logged
potatogun96
Contributor
Reply #2 on:
July 02, 2014, 07:22:17 pm »
Thank you for the advice. I am new to power supply design, and didn't know where to even begin. I will throw the new circuit together on a breadboard and test before I start to desolder parts, but the new design makes sense.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
