Author Topic: Log Op Amp Problem - Odd Configuration - Confused! Help!  (Read 3880 times)
Offline ExtremHybridTopic starter
« on: December 13, 2014, 12:03:31 am »
Hello, I have an odd log op amp configuration I cant solve.
I am given the task to form a mathematical expression for this circuit:
Given to me are:
Shockley ideal diode equation  iD = Is*(e^(VD/VT) - 1) <--- Approximated to:  Is*(e^(VD/VT))
My CONFUSION is due to the resistor R2|O :scared: :-//
My answer for Vout has to include the variables vIN, R1, VT, IS, and R2.
So far, I have Vout = -VT*ln(vIN/(IS*R1+1)) <--- Approximated to: Vout = -VT*ln(vIN/(IS*R1))
And this equation would be correct for your standard logarithmic op amp configuration as shown below:
At some point I came up with the equation:
Vout = -VT*ln((vIN-R2) / (IS*R1))
But this is wrong!  |O
Intuitively I know that R2 is a total dud and it has no function in an ideal op amp scenario.
No current flows through R2 and the voltage at the + terminal of the Op Amp is the same as the - terminal, which is GND (i.e 0V) !!!
But the answer to the problem requires that I state R2 as a variable somewhere in my equation for Vout and I don't know where. If it were a differential amplifier configuration  with a voltage divider connected to the + terminal of the Op Amp, then I would know how to figure it out.
But I am confused and frustrated at this problem. |O
Intuitively I know the answer, but mathematically I can't express it as required. FML.
Could someone PLEASE explain to me what I am missing and where this damn R2 belongs in my Vout equation.  |O
Thank you in advance.
« Last Edit: December 13, 2014, 12:05:10 am by ExtremHybrid »
Offline AG6QR
    • AG6QR Blog
Re: Log Op Amp Problem - Odd Configuration - Confused! Help!
« Reply #1 on: December 13, 2014, 12:25:43 am »
Since you understand that the current through R2 is zero, and therefore R2 is irrelevant, I'd say you understand the electronics.  You're just stumped by the test-taking aspect of the homework problem.
If it were me, I'd include a 0 * R2 somewhere in your expression.  That represents the voltage developed across R2 (assuming ideal op-amp with 0 current through its inputs), and thus it represents the voltage at the + input.
Sure, your algebra teacher would tell you to simplify 0 * R2 to just 0.  But if your EE teacher wants to see R2 in there, put it in there correctly.  You might even use an expression for the input current instead of 0, which would make it easier to adapt your expression to real-world op-amps with nonzero current on their inputs.
Offline tggzzz
« Reply #2 on: December 13, 2014, 12:45:02 am »
Typically, but not always, such "irrelevant resistors" can be understood by considering an op-amp that has a non-zero input-offset current.
For more information, see any opamp "cookbook" or detailed application notes.
Offline dannyf
« Reply #3 on: December 13, 2014, 01:49:29 am »
The non-inverting terminal and the inverting terminal should be at the same potential: GND.
Thus, the current floating through R1 (and the diode) is V1/R1 - here, V1 is limited to be positive.
The output would be such that the current through the diode is V1/R1, and is negative.
Hope it helps.
Offline IanB
« Reply #4 on: December 13, 2014, 03:56:03 am »
Suppose you consider a simplified equivalent circuit for the op amp where there is an input impedance Rin between the (+) and (-) inputs of the amplifier, and where the output voltage is given by Vout = G Vin = G (V+ - V-)?
A current Iin = Vin / Rin will then flow whenever there is a differential voltage between the inputs and the resistor R2 will become relevant.
Offline tggzzz
« Reply #5 on: December 13, 2014, 09:07:30 am »
They will be at the same potential. However, since there will be a common-mode input offset current, it won't be GND.
Some opamps have very low common-mode input offset currents, but logarithmic amps will also be operating with very low currents in the feedback loop.
Offline mikerj
« Reply #6 on: December 13, 2014, 09:19:27 am »
In practice yes.  For a homework assignment where no other information is given, it would be reasonable to assume a perfect op-amp.
Offline dannyf
« Reply #7 on: December 13, 2014, 11:01:04 am »
If you were to consider Is and R2, it is equally simple:
the two input terminals are at the same potential. Assuming that Is flows into the opamp on the non-inverting end alone, the non-inverting end would be at -Is * R2.
So the current going through R1 would be (V1+Is*R2) / R1. and the math follows.
You can extend this to a case where Is is present on the inverting input terminal as well.
You can also extend it to cases where input offset voltage exists, etc. But for a typical opamp, it makes minimum difference.
Offline tggzzz
« Reply #8 on: December 13, 2014, 03:07:31 pm »
That, of course, depends on what the assignment is designed to teach.
Since the OP was given that circuit, it is plausible that including the common-mode input offset current was part of the assignment.
