If using with a switch yes, if using from the output of another IC no. Pull up for CMOS is very forgiving, you can use from 220R to 1M at low speed, though you probably will want to stick to around 2-10k for most cases. Connect unused inputs to a power rail via a 10-100k resistor, otherwise they will float and may oscillate.
