Hello everyone!
I'm trying to set up a small lab now that I ended my studies and I'm looking for a good power supply, so I wanted to ask you all first. I have two transformers here from an old never done project, a 15V-0-15V 5A and a 30V-0 5A transformer (both are same size and weight).
At this point I'm considerating some options to fit them in a good power supply/supplies:
- Just one big power supply, capable of handling 100V 10A, so by choosing parallel/series transformer I could get two ranges of 60V 5A or 30V 10A
- Use two separate power supplies 30V 5A, and series/parallel them when needed
So, I'm thinking about the connection in the diagram attached, which will allow to use two 30V 5A power supplies, or 30V 5A and 15-0-15 5A supplies (maybe the 15-0-15 could be used too while using the other two 30V 5A, but not sure about that because will need to be sure current will not get that high from center tapped transformer).
So far I've being looking at two main possibilities:
- Simple LM723 schematic with current limiting, for example
http://electronics-diy.com/30v-10a-variable-bench-power-supply.php.
- But, as I've been hearing lot of bad things about poor 723 current regulation, I'm considering this one too with an LM317 without current limiting, LM317HVT will be needed as voltage will be more than 40V actually. An example of 10A 30V with LM317
http://www.cuteminds.com/en/elettronicagen/electonics-projects/55-alimentatore-variabile-1-30v-10aAt this point I would like to ask you all which option you think will be the best one to do the best with those two big unused transformers I have, and if can recommend any good power design supply for my needs. I don't need ultra low ripple or so fine regulation, and I'm not even sure if I will need current limitation, so any help/schematic will be appreciated.
Thank you all!
