I think you will find the more problematic issue than buying a power supply, will be building a collection of the various sizes and types of connectors that fit the input power connector on the laptop.
I have used some of the Kensington and Targus products. The nice thing is that some of their units come with multiple tips that you simply connect to the cord, and the tips alter the output voltage, and set the polarity correctly. I believe Kensington also has a number you call, where you can get additional tips if you find a laptop that isn't supported by the tips that came with the charger. I believe they will give you several for free, before asking for a small fee for them.
If you wish to use something like the above, and want the ability to monitor power levels, it would be fairly easy to cut a cable and add a DMM in line. You would need to look carefully at the burden voltage of the meter you use, as at currents in the several amps, this could get large enough with some meters to cause problems with the laptop not having enough voltage. (Caused by the voltage drop in the meter put in series to sense current.)
The other possible thing for power sensing, is to sense the input power to the Kensington or Targus you buy. A unit like the "Watts Up?" or the "Kill-A-Watt" would likely serve your purpose. I don't remember which had the better specs off hand, so do look at that before buying if you go that direction.
Anyway, this is an area that I've done a fair amount of work in, and I would suggest the Kensington units for you, as the connector problem is a real issue if you don't have access to all the connectors for the various laptops. Unfortunately there are a huge variety.
If you do go the route of a Kensington or Targus, you will probably need to buy a higher wattage supply from Apple to support the MagSafe connectors on their products, as that connector is protected by patents, and as a result Kensington and Targus can't make connectors for those products.
