I found this press-in diode (see attached pic) in a crusty old power supply that was part of a lot I won at auction. It's an Electro-Technic Products "Model 6000 Variable Voltage Power Supply." I estimate it to be mid-80's vintage. And it looks like someone made some attempt at repairs, to put it kindly
(you'll see what I mean if you'd like to check out photos of the teardown - they're in my dropbox at
https://www.dropbox.com/sh/qhmn6kz90b03pqs/AADSRMPHU-oi28Kk6WjxBExPa?dl=0 ). This thing interests me because I've never seen a variable transformer like the one used here that has a plate that is connected to the control knob and brushes along the windings as the operator turns the knob in order to vary the output voltage.
Anyway, I have had no luck so far trying to find some info about the pair of diodes. The mark looks like it says "5L11N 207".
Any ideas about whether it's feasible to track down info on an old diode like this, and if so, where to look?
