Well first I would advise you to get rid of the everything can be bought sentence in your head.
Yeah it might get bought but:
- it does not do 100% what you need to be done, and 90% is that good enough for you?
- most systems are closed, so adding some of your own stuff ain't going to happen or it needs so many frustrating workarounds
- you did not create it, you miss the fun and inside glory of having created someting yourself
Some projects from the past years:
- soft start for my subwoofers since they tripped the fusebox
- hometheater automation with triggers: amps start up, shutters go down, screen goes down etc.
- DUT box for the hobby (box that enables and disables big power relay for power of the device under test).
That said, some of my current projects where I lack the time to finish them so they keep on going and going
- LED lighting system, simple DC Leddrivers controlled by easy RS485 based protocol. Led lamps are in place, drivers finished now I still need a wife friendly nice looking probably LCD touch color lcd control panels that can also function for future projects.
- simple garagae led lighting system, each lamp has a small pir sensor and works automatically with simple dimming time out and overrule. Also RTC to dim lights after 20.00 in house not to wake up the kid who is asleep. And dim very very low after 0.00 so you don;t wake up too much if you have to go to the bathroom in the middle of the night. Perhaps replace/expand with red (night vision u boot idea) lighting instead not to wake up at all
Future projects:
- home data sensing (doors, windows, shutters, light, humidity, temperature) still in the thought area, this will take so much time esp. the wiring etc. that it probably be stuck in the thought process but that's ok.
- Adding IP interface to existing projects
None project based hobby activities:
messing around with STM8 and ARM microcontrollers and reading the forum/literature and playing with new components etc. etc.
