I have a simple basic design question (maybe the answer won't be as simple). I want to make a dumb water level detector to light an LED when an opaque water tank is empty (love my plants...)
Problem is: I'd like to power it by battery, and if possible make it last very long. So I went with a simple Not gate with 2 NPN transistors.
This design is plain and simple, but actually it's when the probe is closed and the LED is off that the consumption is the most important. I measured about 600Kohms when the "probe", actually just 2 jumper wires, are in the water. I tried multiple resistor values, I can live with an LED consuming some mA, but the LED consumes less current than the R1 resistor put to ground by Q1. If I increase the values too much the LED is too dim. I tried to put another NPN in Darligton configuration, it worked better with high R1 values, but still too high for my liking. I also tried using a 555 to make the LED blink, hoping I would get a better lighting/consumption ratio, but it increased the quiescent consumption of course, so it doesn't solve my problem.
I measured values as low as 1mA, but with a 1200mA/h battery that would only last a month or so.
I'm curious about an elegant solution to this problem if there is any.
