Hi everybody,
Doing some research on the web about my problem, I found out about this forum and decided to give it a try.
As you can see on my schematic, I have a battery connected to a heating resistor, their low sides are separated by a NMOS (
https://www.infineon.com/dgdl/IPB039N10N3+G_Rev2.1.pdf?folderId=db3a304313b8b5a60113cee8763b02d7&fileId=db3a30431ce5fb52011d1ed1fd3915e0)
BATT- is then connected to the GND of my circuit through a sensing resistor (10 mOhms) for other purposes.
I tried this circuit with a power supply in place of the battery and noticed it would immediately drain current. To be sure it wasn't a command problem, I removed the gate resistor (R12), but it's still happening. When my power supply is at 20V, Vds = 2V and Vgs = 300mV, and the mosfet acts as a very small resistor. But it should act as an open circuit!
I tried with R13=10k, R13=0 and without R13, and it's always conducting.
What is going on? Everything I've found elsewhere displayed the exact same schematic, even a board I've already used worked the same way. What am I missing here?
Thank you for your help, strangers!
