I'm attempting to remove some of the high(ish) frequency noise (15khz-20kHz) on some speaker lines, and I've decided to use a low pass filter with a capacitor and resistor. The issue arises when selecting components. The speaker is about 400 watts, and I need to make sure I don't burn out the resistor or cap. The peak voltage of the speaker should be somewhere between 40 - 50 volts, and I'm not sure if I should you low value resistor and high value capacitor or visa versa. I'm fairly sure that the higher value resistor I use, the lower the maximum volume of the speakers will be. Any ideas? I feel like this should be a pretty simple V=IR and P=I2R calculation, but I don't want to end up burning something down. Thanks in advance!
