Hello,I have two qestions, if you can help me.What happens after you pass the 3db point of a LPF,
and witch is the maximum ° that you can obtain with a LPF?
A single R and a single C makes a very poor filter. it rolls off at only 6dB (half the level) for each octave (10 times the frequency). Use an opamp or a few to make a multi-order active filter.
