Hello all,
I've been working on a small project that needs a negative voltage rail and after trying out a whole lot of different options (virtual ground, two batteries, etc.) and decided on using a dedicated IC (LT1054IP in this case to give me a simple unregulated negative voltage). I am basing this on a circuit in the LT1054 datasheet.
In simulation, the circuit works well but breadboarding it resulted in me only getting a positive 5 Volts at the output.
Any advice as to what I might be doing wrong?
