Hello,
I am trying to build a small backpack for a video transmitter and an integral part of schematic is a voltage regulator which gives me 5v 1A from a 12.6v source. As I have a few of those LT3080 at hand in SOT-223 package I thought I could use those. Looking at the datasheet I can understand that how to get the output voltage down to 5V but the heat dissipation with a resistor gives me a bit trouble. I am choosing the resistor in parallel solution but can't seem to calculate the correct value. With the following circuit parameters:
Vin = Vcontrol = 11.1V (SOT-223 has those pins connected)
Vin(max) = 12.6V (3S LiPo battery)
Vout=5V
Iout(max)=1A
Iout(min)=450mA (assuming Rp carries no more than 90% of Iout(min) = 405mA) <- don't exactly understand what this part means
I get:
Rr = (12.6-5) / 0.405 = 18.77 ohm (so with a standard 5% its 19 ohm)
Max Power Dissipation calculations:
(12.6 - 5) x 1A = 7.6W
1A - (12.6-5) / 19 = 0.6A
Pdis = (12.6 - 5) x 0.6 = 4,56W
Rp= 7.6-4.56 = 3,04W
So I need a 19ohm resistor capable of handling 3W?
I attached the eagle screenshot of my circuit and the LT3080 datasheet is
here
