I still don't understand your concern. Consider these models:
Jay_Diddy_B, you don`t understand my concern?
For clarification, we do not need new or modified models.
You only must answer my
question:
Is the ac test source in all three simulation schemes (post#7 and your last post) inside the feedback loop?
Obviously, the answer is NO!
Instead, these sources are grounded and the loop is still closed. This is the result of a simple visual inspection and cannot be denied.
Hence, all of your simulation results might be identical -
but neither shows the correct loop gain.
For illustration purposes, Let me discuss a
simple example:
Consider the classical non-inverting opamp amplifier (feedback chain R2-R1, with R1 connected to ground.)
For testing the loop gain, we open the feedback loop and place a test source BETWEEN opamp output and R2.
(This is sufficient because the loading effect of R2 can be neglected).
What YOU did in your simulation arrangements was to place the test source between R1 and ground!
As a result, you get the transfer function of the corresponding inverting amplifier model - but NOT the loop gain.
Both transfer functions will, perhaps, exhibit a similar phase response, however, the magnitude - and hence, the point where we find the phase margin - will be not the same.
Do you now understand my concern?
