Hi all. A quick question. I want to simulate an LT1494 opamp for a circuit I'm designing. Basically it's just a differential amplifier used in a rail to rail application. My question is: to what length does the simulation model go to match the performance of an actual device? You can see in my schematic (attached) that I have a +12v supply powering the opamp, but the opamp input goes up to 24V. According to the simulation, there isn't an issue but there would be in real life.
Also if anyone has any good recommendations on learning LTSpice, I'd appreciate it!
Thank you.
