I have decided to build a 3W IR/RGB/white/UV light source. I'm using 12v from an ATX psu to power a lux drive 700ma buckpuck (3021-D-E-700). For some reason when I connect the IR 3W 700ma LED to the driver it will supply ~1amp. All of my other LEDs are rated for 700ma, and all of them will not draw more than 700ma. I've already burnt out one IR LED, I don't understand why it's drawing more than the max of the driver. If the problem was the driver, why don't the other LEDs have similar problems.
