Helo,
I am designing a project in which i need two clock sources (LVDS) one which is around 1.677 Mhz (2^24/10 MHz) and another which is 167.7 MHz (2^24*10 Mhz), one of them will be active at one time,(so i need to select between them) Currently i have two CMOS oscilators one in each desired frequency, then i use an Analog Mux to select the frequency i want and finally i feed the CMOS signal into an LVDS driver. However, i believe, and i think you will agree, this is not the smartest way to do it
My question is, is there a better more efficient way to do it, like using a PLL (I have searched but i couldn't find any).
Thanks in advance.
PS. Since i'm new to this forum, i wasn't sure if i should create a topic in the Beginners or the Project Section, so if you think this is off-topic, please correct me
