Hi all, I'm not an engineer, I just happen to like Dave's work and have no big knowledge in electr(on)ics. But I'm sure you guys know the answer. I have a wall outlet at my home that has a power strip connected. The strip has a switch and a few devices hooked up to it, including a PC with a beefy supply, its monitor and a desk lamp. The trip device in the garage often goes poof when I switch the strip on. I know what causes this (or I think I know –– "transients", is it?) and I know that I can switch the devices on one by one to avoid making the trip device flip.
Question: is there something I can make, or a device I could add to the circuit, to retain the "one button switches all" functionality without the trip to go "whaaaaaa"?
Note: I can solder and I know basic electronics parts (I've fooled around modding Commodore Amigas back in the day).
Edit: I know it's high voltage, high current. I will not put myself in danger. I don't muck around with mains. I'm just curious if a solution, theoretical or ready-made, exists.
