I've been reading the depletion mode mosfet section on The Art of Electronics, and decided to place some of these devices (
LND150) in my next order to Mouser. As a first experiment, I'm thinking about a zero cross detector for mains:
Here the mosfets play the two roles from TAoE, input protection for the comparator and discharge for the mains capacitor. Additionaly, they provide a neutral referenced bipolar power supply which, if I pulled it right, is an interesting twist.
Is there something I've overlooked that could result in pirotecnics? I haven't found any spice models for small depletion mosfets, so I'm basing myself in calculations and a very limited experience with these devices. Of course, in case I build the circuit, I'll use an isolation transformer. Given the nature of the power supply, all the components should be very low power. With the comparator there's no problem; I wonder if the optocoupler could be replaced by magnetic coupling, to reduce power.
