Hi
Hmmm .... minimum parts ...AM radio ...
Ok, spool of wire:
Some is wound into an air core inductor
Some is wound into a free air coil pair as a speaker
Some is paired up as a capacitor or two or three.
You still need the diode ... errr ... coper oxide ... heat it up and you have a "diode"
Some to string out for a *really* long antenna (you need a lot of volts for this beast and at uV or mV / meter .. yikes)
It's a really awful way to make a radio. You will use a monster spool of wire. It will work very poorly.
One part is about as minimum as you will get though.
Do I get a prize?
Bob (running quickly from a variety of thrown objects ...)
Now you *might* question the operation of this device. I once lived near a 50KW AM station and could quite easily light up a pilot light from their signal in to one of my long wires. I made several "interesting" radios to pick up their signal. Not all of them were *intended* to pick it up.
