In an old scrap CRT color TV or CRT monitor, you can salvage all the components needed to make your own 20KV power supply project for nothing or very cheap. (ferrite flyback transformer, high voltage power transistor, voltage multiplier, high voltage capacitors, ...)
As this kind of power supply is current limited with high internal resistance, a shunt regulation would be very simple and should have a great stability.
