I got one of these
https://smile.amazon.com/Source-Makita-Li-ion-Battery-BL1815/dp/B0725LWR1L/ref=sr_1_1_sspa?ie=UTF8&qid=1517971745&sr=8-1-spons&keywords=adp05+makita&psc=1I hooked it up to fully charged batteries and connected a voltmeter to the USB post and the voltage started at 5.2v and immediately started dropping and within a minute it was around 3 v when I stopped the reading.
At 50 ma it stays on and at 25ma it turns off.
I want to use this as a portable PS. I also need 9v sometimes, so I will use a boost module from Aliexpress. Also I want 3v (or is it 3.3v ?) so I will use a 317 module.
My guess this has something to do with a minimum current required by a buck but I expected Makita to design the circuit to stay at 5v regardless of current.
So I will have to put a 100 ohm resistor across the battery (5v). Or 4 LEDs ?
Is there any simple way to turn off this 50ma waste when the real load reaches 50ma ?
thanks
