Buying non working equipment is a very risky business. You have to buy really cheap to offset time, effort, parts and resources required for a repair (which is by no means a guaranteed to work). Of course, you will get some experience by doing it, but is not a best deal.
With regards to acquiring equipment by repairing broken stuff - it will take forever for you to do it this way. As you stated above, you have little electronics experience - repair jobs won't be easy in many cases. On top of that, you will proper working equipment for repairs which you likely do not have right now. Also, time and effort consumed with fiddling with partly working stuff is underestimated - expect for broken stuff to accumulate.
I suggest to take a slow approach - buy some working test gear at first, try few repairs and see how it goes from here. If you like accelerated approach, try working in a repair shop - you will learn much quicker.
