Manually shift subtitle displayYou can manually adjust the subtitle position on the TV screen.1 During play, press OPTIONS. » The play options menu is displayed.2 Select [Subtitle Shift] in the menu, and press OK.3 Press the Navigation buttons (^ v) to shift the subtitle, and press OK.Subtitle shift is not supported for DivX video with external subtitles.
[Auto Subtitle Shift]Turn on or off the automatic subtitle shift.• [On] - The subtitle position on the TV screen is automatically adjusted.• [Off] - Disable the automatically subtitle shift.
