I am going through a data sheet for a boost controller - TI TPS43060. In the section about calculating the output caps, I am not getting the same answer as the datasheet example.
Equation (24) when I solved in excel gives me 53.3uF where the datasheet answer is 21.3uF. Am I wrong or mis-interpreting what seems to be rather simple. Equation (23) evaluates as expected.
excel:
=(0.6*5)/(750000*0.075)
Thank you for any comments. I am more than willing to put on a dunce hat if needed.
