Whilst trying to get the hang of Eagle I continue with matrix pad boards. I see some suppliers offer a matrix pad baord with a plain copper ground plain on the reverse side, making an easily accessible ground from any point on the board. If you don't want a leaded or pinned component to be grounded you remove the area around that pin, on the ground side, with a drill bit. It seems great for many projects. Does anyone have experience of this? I could envisage high capacitance if you were not careful with high frequency circuits, but I rarely build such stuff save on commercially designed boards. Thanks for any insights.
