Hi, I'm playing around with the M9712. I have it hooked up to a 1.5 AA cell and set to CR.
The display switches from CR to Unreg when I get up to about 63 ohms. I checked the specs and it says,
"CR Mode (Voltage and current input value >or= to 10% full measurement) What does this mean ?
Since I can place the cell across a 100 ohm resistor and measure the current I'm starting to wonder if something is wrong with the M9712.
Please help with my ignorance, thank you.
