Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
MCM6206DJ25 (static ram) replacement (and response time problem/question)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: MCM6206DJ25 (static ram) replacement (and response time problem/question) (Read 1499 times)
arekm
Supporter
Country:
on:
December 13, 2013, 12:26:07 am »
I need to replace 32k x 8bit sram chip - MCM6206DJ25 (
http://datasheet.eeworld.com.cn/pdf/MOTOROLA/120846_MCM6206DP25.pdf
). What's best place to look for replacements? I mean sites that list compatible parts.
I found AS7C256A-20JCN available here in PL (by just looking for sram chips) but it's 20ns memory while original was 25ns. Not sure if replacing with fastest response time is going to work? Also AS7C256A-12JIN 12ns (
http://pl.farnell.com/jsp/search/productdetail.jsp?sku=1562910
) if I order at farnell.
Last Edit: December 13, 2013, 07:24:56 pm by arekm
Logged
SeanB
Super Contributor
Country:
Re: MCM6206DJ25 (static ram) replacement (and response time problem/question)
Reply #1 on:
December 13, 2013, 06:00:14 pm »
Faster will work, it will not worry that it is faster in many cases. Slower can work, but will be dicey depending on just how much window there is left to latch the data off the bus while it is valid. Faster will have it there sooner and will wait..
Logged
peter.mitchell
Super Contributor
Country:
Reply #2 on:
December 13, 2013, 06:19:58 pm »
The specs on the datasheet seemed fine, but the logic block diagrams looked a bit odd relating to address lines...
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
