I'm designing a VFD driving circuit. One of the challenge is the driving chip needs -22V negative bias.
I found Dave has an inverter FF tutorial based on a MCU generate waveform. But it can only provide -VCC instead of "boost" the voltage lower.
So I came out the attached design, basically combining a boost converter with Dave's inverter.
Can someone scrutinize my design before I put it onto a board?
Thanks
Baoshi
