Hey everyone!
So I wanted to ask you all for your opinion on a design change I am working on. I have 4 lines of various voltage (5v, 3.3v, 2.5v, 1.8v) each at 200-500ma. And I want to use a microcontroller (Atmel in this case) to control / switch a line out that then connects to a level shifter IC. My current board, this is done with just a SPDT switch.
So this is what I came up with:
So I have 4 lines from MCU, going through a resistor array (220 ohm), and then each to a LED and then to the enable pin on a ADP197 (High-side power switch) and the output of all 4 of those tied together that then goes to the voltage-ref of the level shifter / translator (FXMA108).
So my question, is there anything I am missing? I was thinking that there could be a problem with the boot-up, as vcc might try to enable all 4 of the power switches at once, but the level shifter is controlled via its own OUTPUT ENABLE pin, which I have a pull-up resistor (10K) so that it should remain in 3-state until the MCU is ready and can pull down the OE pin.
