I tried a 330K resistor with 10 Volts (from my benchtop power supply).
I expected 30 mAmps, but the meter showed 11 mAmps.
Naw that ain't right. You should expect .03 mA.
(see above posts ...)
Sorry, decimal error. You are exactly correct.
Also, after taking off the cover, it does appear that the fuse is blown. (if my eyes are seeing correctly)
I expected to see 2 fuses, but I just see one.
The fuse appears to be marked: f315mAL 250V
So I assume the fuse is a "fast blow" fuse
designed to handle up to 250V
and only 315mAmps
I am not sure what the trailing "L" means however.
Does that sounds right?
Anyways, I will replace that, AND the 2 double AA batteries.
Then I will plan to post a follow up.
