Hi there,
first of all, i am a beginner when it comes to oscilloscopes, so please don`t be too hard with me
I am working on a little PWM based led dimmer, using a n-channel mosfet (IRLB8721) to dim some 12V led strips. It seams to work as it should.
Now i want to measure and compare the 3.3V logic signal with the 12V Output signal, to see if the mosfet switches all the way and to check the timing...
Now my question: How can i measure the in and output at the same time with only one 2 channel oscilloscope (Siglent SDS1102)? Is that even possible?
As far as i understand, i need a reference for the scope, but for the logic signal it would be ground and for the Mosfet +12V right?
But the clips from both channels of the scope are directly connected...
Anyway, i hope someone can help me out, thanks in advance!
Greetings from Germany
