Your scope has a nice test generator on the right bottom corner, just use it, to see a better wave and check from where the noise come from.
Noise is the less desirable thing and most present in any circuit don't be afraid of some noise just look and tell this is noise this is signal, later on you can make advanced research on noise, It's not a good idea to fight noise while learning, just assume " ok, that is noise"
