My electronics knowledge is a bit rusty, so I'm double checking here.. I'm having some trouble measuring voltage with arduino: the readouts kept fluctuating. So I figured out something is wrong with my aref/power supply. So I measured the voltage of the usb, which I'm using to supply the arduino and it is 4.6v steady. But when I switch to AC voltage measure, I should expect near 0V, right? It's reading 0.3V - does that mean the usb power is going up and down for 0.3V? I don't have oscilloscope to double check it..
thanks,
Žiga
