Author Topic: Measuring capacitance (R+C as voltage divider confusion).  (Read 3634 times)
« on: June 12, 2014, 08:23:01 pm »
OK, the background to this is that I have recently acquired a Seaward Primetest 100 PAT tester1. I have a Primetest 50 which I use for electrical safety testing of stuff I sell on ebay2 but I haven't been totally satisfied with it as it only has a "pass/fail" indication and doesn't do leakage current3. The Primetest 100 displays the insulation resistance and the earth bond resistance and adds a leakage current measurement.
There was no cal certificate with the unit so I want to make sure it works properly, to check the insulation resistance/leakage measurements - I came up with this:
The test voltage for insulation resistance is 500V hence two 510k resistors rather than a single 1M resistor and the high voltage cap, I checked these on the Keithley and they came to just over 1.03M - the Primetest read 1.04M so that's OK.
Now, caps tend to have wide tolerances and only relatively few values are available - I wanted to have a total AC leakage current of 0.75mA as that's the regulatory limit so I thought I could trim the current by having a resistor in series.
I have a couple of multimeters capable of measuring caps,  none terribly accurately, but they seem to agree that the 10nF cap is, indeed, 10nF give-or-take a few % That gives an impedance at 50Hz of 318310 ohms - add the 130k (actually 130300 ohms) plus the current through the two 510k resistors and that comes to 0.766mA.
The Primetest reads 0.8mA which although 4% high is actually in spec which is within 5%
Unfortunately this doesn't validate the PAT tester as well as I'd like - knowing the test values to only a similar tolerance to the meter spec isn't really good enough - I'd like to aim at something closer to 0.5%.
So I had the clever idea of measuring the impedance and working out the capacitance from that. So I took just the 10nF cap and 130k resistor and drove them with a 50Hz sine from my sig gen.
The SG goes up to 20V p-p (into a high impedance load, 10Vp-p into 50 ohms) which is 7.071V RMS, I measured 7.079 on the Keithley 2015.
BUT I get 5.866V rms across the cap and 2.387V rms across the resistor - I sort-of expected these to add up to 7.079V, not 8.25V
My brain does start to hurt a bit when we get to AC circuit analysis - can anyone explain the measurements without getting too mathematical? I thought I could ignore voltage/current phase differences with this set-up but perhaps not. I'm reasonably certain the readings  are correct.
[1] At £30 "not working" I couldn't resist - it just took cleaning the battery contacts and the PCB pads for the front panel buttons and it was fine. Sadly while the other £30 Primetest 100 that I got at the same time responded to a similar approach it also turned out to have a real fault as well. You win some, you lose some.
[2] Partly because I think it's a good idea and partly because I think that the Electrical Safety Regulations 1994 say you have to - I'm probably the only ebay seller who bothers though.
[3] This now gives me the conundrum that the Tek 2035 that I'm working on "failed" the leakage test. Lots of discussion on the Seaward forums about similar problems with PCs - probably due to the mains EMC filters.
« Last Edit: June 12, 2014, 08:25:36 pm by grumpydoc »
Offline Andy Watson
Re: Measuring capacitance (R+C as voltage divider confusion).
« Reply #1 on: June 12, 2014, 08:39:56 pm »
How much capacitance does the input to your meter have?
« Reply #2 on: June 12, 2014, 08:42:56 pm »
Spec says < 100pF
Offline Andy Watson
« Reply #3 on: June 12, 2014, 08:50:06 pm »
I think you should be reading 2.677 Vrms across your resistor and 6.554 Vrms across the capacitor. Something in your measurement system is imposing a not insignificant impedance in series with the components that you are measuring.
« Reply #4 on: June 12, 2014, 09:04:16 pm »
Can't see it putting anything significant in series, it's just a resistor and cap soldered in the middle, croc clips to the other two leads and measurements directly at the components.
Of course, duh, the input is 1Mohm plus <100pF and the 1M is going to significantly affect the readings.
In fact double duh because Dave did a video  on the subject.
However it doesn't actually help my confusion - that will go in parallel with the component and should tend to reduce the reading.
Offline Andy Watson
« Reply #5 on: June 12, 2014, 09:31:08 pm »
The 1M is probably making the difference. I had assumed that, being a DVM it would have a resistive input component much greater then 1M - one too many assumptions :)
When you add capacitive (or inductive) components to resistive components you need to use vector addition, i.e. Zrc = sqrt(R^2 + Xc^2). Workout Zrc,  then use V/Zrc to find the current (the current must be common to both the capacitor and the resistor in this series circuit).  Find Vr by simply multiplying, I x R. Ditto, find Vc by multiplying I x Xc. If you've done it right you should be able to add the voltages together using vector addition and get the voltage you started with, i.e. Vosc = sqrt(Vr^2 + Vc^2).
« Reply #6 on: June 12, 2014, 10:06:04 pm »
Yeah, I was thinking of the >1Gohm spec for the DCV range, completely missing the fact that the AC input is totally different.
Allright, with the 10nF as an example:
The impedance of the cap at 50Hz is 318310ohms, so the combined impedance is sqrt(1303002+3183102) or 343947ohms
current = 7.079V/343947 = 20.58uA
voltage across resistor = 130300x 20.58uA = 2.682V
voltage across cap = 6.55V
OK, that's more-or-less what you got
Checking - sqrt(2.6822+6.552) = 7.078 (close enough given rounding). :)
The Wikipedia page says that for an RC divider (or low pass filter) would have a Vin/Vout ratio of
Plugging the values in would give 6.54V across the cap so that agrees.  8)
My next problem - apart from how to set up the measurement, is this:
If the impedance of the series RC network is 343947ohms, not  448610ohms then the current through it at 240V1 is 0.698mA - add the 0.23mA going through the two 510k resistors and that's 0.929mA
So either the Primetest is reading woefully under or I still don't understand the calculations  :-\
[1] the Primetest doesn't actually measure at 240V - it does a "substitute test" where it measures at 40V and scales the answer by 6.
Offline Andy Watson
« Reply #7 on: June 12, 2014, 10:41:12 pm »
Ah but, the current through the RC path is no longer in-phase with the current through the two 510k resistors - so you can't just add them.
Going beyond one R and one C does start to get mathematical! I've not done this sort of analysis like this for some  30 years and I would have to have a good think about expressing the problem with phasor diagrams. - that's as simple as the maths gets. On the other hand, if you don't mind delving into complex arithmetic (i.e. imaginary numbers), the way I would tackle this problem is to express each component in its complex form and then use the standard series/parallel impedance formulas to arrive at an impedance for the whole network.
Do you know how it arrives at the voltage reduction? If it is using a transformer then you can probably ignore it, but if it is using a resistive or capacitive divider you will need to factor this "burden" into your calculations - you will no longer be applying 240V across your phantom load.
« Reply #8 on: June 13, 2014, 07:48:07 pm »
I'm actually pleased to hear that since I'd prefer the conclusion to be the Primetest is so-many% accurate not "it's broken"
If I can't work it (current through the network),  can I measure it by sticking a sense resistor at the top of the network and looking at the voltage across that?
I've started to realise that!
Phasor diagrams are probably the way to go - especially as I found some notes at http://www.kwantlen.ca/science/physics/faculty/mcoombes/P2421_Notes/Phasors/Phasors.html which include a worked example - a sub network of which is the network I want to solve.
Even so it will stretch my maths to understand it - I can sort of see what's happening geometrically but it's a long time since I did any vector math.
It doesn't start with 240 and reduce down, it starts with 9v (6xAA) and generates 40V rms @ 50Hz - not sure how it current senses.
One thing this has done is provided a concrete reason for buying an LCR meter - I think I might be able to figure out the maths for the network if I take it in small steps (and possibly with some hints) then figure out how to measure things to confirm if I know the values. I doubt my maths is going to be up to re-arranging the stuff to come up with the cap value from the measurements.
« Reply #9 on: June 13, 2014, 09:00:07 pm »
OK, well it's more plugging the numbers in than properly understanding what is going on but I get an impedance of 294947ohms for the combined network - that gives 0.813mA leakage at 240V which is pretty much spot on what the Primetest 100 is reading, phew.
I understand AC networks a lot better as well - not nearly enough to fly solo but definitely enough to know what to work on to improve my knowledge further.
Andy, if we ever meet, I owe you 1x the beverage of your choice.
