I am trying to plot the charge current with an oscilloscope but I am getting weird readings.
I am using a homemade shunt resistor, basically just a piece of wire that I measured with the 4-wire method to be 0.01 Ohms. There's no other resistor in the circuit, just the cap.
I am charging the 1000u cap with a bench power supply set at 12 Volts, capable of 3A max.
When I close the circuit, the voltage across the shunt goes all over the place, even reverses polarity. (doesn't that mean that the current flows backwards?)
When I measure the voltage across the cap I get a nice clean, textbook-style charging curve. The cap reaches 12V at about 10ms so using the C*dv/dt formula that gives 1.2 amps
What am I doing wrong?
