Even a 10x probe will introduce trouble. You're loading the crystal, and adding capacitance which will change the frequency. You need a high impedance (100x or even better FET) probe to even try to measure the crystal directly with decent results. And that will _still_ pull the frequency a bit.
Focus on the oscillator output, instead.
