Hi everyone,
I designed a circuit with a PIC24F and a couple more components and now I want to measure it's average current in different modes (run, idle, sleep) to later estimate the battery capacity I'll need. What sould be the best procedure to accomplish that? Im expecting to get very small currents, in the range of ~100mA (run/idle mode) and ~10's uA (sleep) or even ~100's nA (deep sleep).
I have a Rigol DS1052E Osciloscope and a Batronix BXM98P multimeter (true rms, 4 1/2 digit). I can also borrow an current probe if needed.
I considered to use a 1ohm resistor in series with circuit's VDD, two osciloscope probes and use ADD function of the osciloscope to get a differential voltage across the sensing resistor. I don't know if this method is reliable to measure such small currents due to osciloscope's vertical noise and CMRR between the two probes.
What are your suggestions?
Thanks
