Author Topic: Measuring Electrolytic Caps  (Read 1763 times)
Offline carboncompTopic starter
« on: January 30, 2014, 06:07:25 am »
Iv got a relatively new Extech  330 multimeter (got it 3 months ago) but It just wont measure electrolytic above 47uF  :-//
The datasheet says the range is 0.001nF to 200?F so guess its faulty or I'm doing something very stupid!
Any troubleshooting suggestions?
Offline Rerouter
Re: Measuring Electrolytic Caps
« Reply #1 on: January 30, 2014, 06:25:21 am »
that ? is because there blog software doesn't recognize the micro symbol, so its upper range is 200uF,
as for why it cannot handle above 47uF, it could be esr or a leakage current making it think its higher,
Offline sleemanj
  • Professional tightwad.
« Reply #2 on: January 30, 2014, 06:49:06 am »
How long are you giving it to perform the measurement.  Measurement can take quite a while as caps get bigger.
« Reply #3 on: January 30, 2014, 12:44:21 pm »
I'm leaving it a good whiles 20+ seconds (using both clips and probes) but it will just show 0.000uF or sometimes around 20nF on brand new 47+uf caps, and have even tried shorting out the caps beforehand.....think its time to return the bloody thing!
