On the DT meter 830B (factory fused version of it), improvised clamp probes I made show 0.4 on the 200 OHM range. Now, how much that can be trusted, who knows. Although, I'm only using those leads to measure resistance, so if that's anywhere near accurate - an addition of 0.4 shouldn't be an issue.
I had a beloved 830D version as well (it has a beeper and it sounds good, no issues) but I noticed some problems with the contacts recently, and then I saw this:
Now, I'm not blaming the meter on that, I did use probes from another meter in it, which might have slightly wider contacts or such, and when adjusting them to fit, I definitely plugged the probes in/out many times. Well okay, perhaps on a higher quality meter this wouldn't happen, but I still really like this one, it worked well for a while, so I hope to fix this somehow.
Does anyone know if a replacement part might be available form China, or should I try to solder some bridge and glue the part to the plastic? I'm
not using this for any high voltage testing, and I'm not putting my life at risk if the quality of contacts is not perfect. I would rather have it back for continuity testing, low voltage and current tests, than throw it away, if possible.
