Well I Figured out the problem.
I was using 9V battery voltage divider as a source. So I hooked up the wires to the 5V divided voltage.
As result I was adding more resistance to the circuit making the voltage divider drop the voltage to 1..V, no wonder it did not work.
After I tried this with a proper 5V source & applied pressure to the cell, I did see changes in voltage.
Without an op-amp (0,2mV without load) & (0,2-1,3mV with applied pressure)
With an op-amp 3,6 - 4V (so much fluctuation without load) (with load applied pretty steady 4,4V). I assume this is what you meant by an rail to rail op-amp.
I am still learning how those op amps work, have been watching tutorials for a week now. I kinda understand how they work & kinda dont...Im working on it.
Edit: Don`t what was causing those fluctuations earlier, tried 2 different setups with voltage divider & external 6V supply on the op-amp, got very beautiful & clean results. from 5,4V -1,3V when applied pressure on the cell.
Ill go search, see if I can find a way to supply 5V to the op amp & hope i can configure it to output 5V. I guess its the rail to rail thingie.
Anyway topic can be closed.
Thank you Andy.
