thanks for the replies, I was thinking the same - that there will be current flowing from N to PE - just wanted to confirm with you guys.
No, after I blew up the fuses in my previous experiment - I do not intend to measure the mains ... at all.
However, so many people are asking and trying - that I think this topic should be periodically re-answered.
You know, it seems that the beginners are drawn to the mains the same way as moths to the flame
There is something magical in trying to fiddle with the mains power, especially with doubtful Chinese instruments
One more question, which is more like clarification:
What is causing the potential difference between N and PE? In my building they are connected to each other in the basement. (By the way this is the most common case in Europe.)
Is this potential difference caused by the mere length of the cable and the fact that parts of the Neutral wire are carrying current (people are using things in their homes.) - so there is voltage drop - meaning the Neutral is with lower potential compared to PE, even though they are connected in the basement?
Also the resistance between N and PE is minimal - I think it is about 0.3 ohms - required by law.
If there was bigger resistance I couldn't have been able to blow my power supply - because it is not Earth referenced - it has just 2 prongs plug.
So, when I connected the CRO, the current flowed from N, via the PE, to the Live wire - therefore shorting N and L via the PE and the CRO casing.
If there was big resistance between N and PE - this shouldn't be possible.
I just imagined myself connecting an amp meter between N and PE and turning the power on from the other side of the room.
Just to see what happens...
... as I said moths to the flame
/No, I am not doing, but if someone had already done it - and I am sure people have done it - please let us know the results./
