G0HZU Thank you for the explanation and Drawings
I am going to leave this meter as it is now as its all working
as it should do, the BAV21 I put in has a voltage drop of .600mV
so I am using that in my calculations to calibrate the scale with.
I also changed that Cap for a 1nF ceramic .
Volts to watts
+ 0.600 (diode)
/ 1.414
square it
/ 50
watts to volts
x50
square root
x 1.414
-0600
And the scale seems nice and linear across its range.
If calibrated at 5W it is spot on anywhere from 1-20
I do have a nice enclosure with quite a large analog meter
if i can find it i want to build a new RF meter from scratch
Possibly following your design above if its suitable ?
My thoughts on the new one is to be similar to this one
but measure up to 100w, so SO239 with big internal Load
but also a BNC for a flylead (scope probe?) and to have a scale which
reads 1 - 10 and make 3 switchable ranges,
0-1 , 1-10 , 10-100 .
And I have ordered some of these to keep in stock anyway
http://www.ebay.co.uk/itm/121518325327?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AITI also bought an RF probe and Blew it up within an hour of unpacking it,
apparently they dont like 100w on the pointy end
so I need to learn more about RMS voltages
