this already feels like a stupid beginners problem.
BackgroundI have build a standard TIA-circuit with a fotodiode. To play around with that TIA-circuit I am using a VCSEL, which is powered by a constant current circuit as shown in the picture. Perhaps not the best way, but a beginner's start. When there is no light on the photodiode, the TIA's OpAmp-Output noise is really low. But when the VCSEL irradiates the photodiode, the noise is very, very high (more than expected). Well, there maybe a million reasons for that, but also out of curiosity, I wanted to check if perhaps the voltage at the VCSEL is distorted.
How I connected my oscilloscopTo get an idea about the voltage curve/drop across the VCSEL did it like this:
- Probe's tip --> VCSEL anode
- Probe's/oscilloscpe's GND --> VCSEL cathode
- The oscilloscope's input is labeled with "1MOhm || 15pf, 300V RMS".
Well, also I can not say it for sure, but I killed two VCSEL's with that setup (not during normal operation, but when I tried to do the voltage measurement).
My assumptionBy connecting the VCSEL's cathode with the oscillosopce's ground I created a short-circuit.So far, I assumed the oscilloscope's ground is not really connected to any ground (e.g. main's ground). Instead it would be somehow "only floating." ... but honestly speaking, I have no glue.
My questionIn case my assumption above is right, what is then the explanation why I fried the VCSEL's?
