That triac is probably for the heater, and if you say it's still boiling water, it should be fine. I'd take a look at the pump, see if there's any sort of blockage, or if you can get it to spin up from an external power supply.
Thanks for clearing that up.
I'll try and see if I can power the pump, but wouldn't I need some way to control it? Also do I have to strip the pump from it's cables? I'd assume that would send the current through the whole circuit and cause trouble.
But about the pump: the machine has a drain mode when it drains all the water out of the boiler, and I'm quit positive the pump is working properly during that. When I would drain the coffee machine, it stopped less frequently and the interval between power-up and interruption was a lot longer than when going through it's brewing cycle. Also what I noticed is that when I don't leave any pods in the machine (it just spewing out hot water) the same thing happens (less frequent shutdowns) so I'd think the problem would be at sensor level as TheSolderShack said. =)
I hate it when pretty well manufactured PCBs are ruined by hand-soldered components. They used epoxy and everything!
Hey, at least it's made in Poland, not China =D
But just out of curiosity, is there any detrimental effect but soldering manually?
Do you end up hearing the pump run at all? If so, does it sound normal? You say it also fails when merely boiling water?
The sounds the machine does are normal, whether it's the boiler or pump, I don't know. But I explained above how the shutdowns happen =)
X2 capacitors are pretty damn sturdy and I also don't see it causing the symptoms you have. I'll gladly send you a replacement since I have a few dozen kicking around, but I think the issue is elsewhere.
Here they are quite cheap as well, but thanks for the offer.
The grossness around some of the larger solder pads is going to be some sort of flux residue from hand soldering. Not much to worry about.
That's good news at least.
The BT-series TRIAC is almost certainly, as rexxar said, controlling the heater. A TRIAC works by blocking current flow until a trigger signal is applied to the gate. It then conducts AC current until the next zero-crossing of the voltage. Unless it is continuously triggered or held on by a long pulse, it will only conduct for a half cycle (roughly 8.3ms maximum) before shutting off, assuming it's operating normally. Resistive heaters are exactly the kind of load that a TRIAC likes seeing. I imagine the TRIAC is fine.
Thanks for the details, love 'em =D
